dav-dz230 et decodeur orange
profile.country.fr_FR.title
caneves51
bonjour
quelqu un  aurait il une deja rencontre ce probleme , cest vrai que le home cinema n est pas tres recent mais il decode le dolby digital , au fait  j aimerais passer le son de mon decodeur orange ( tele )sur mon home cineme est ce possible ?
merci de me repondre si quelqu un a une astuce
1 ANTWOORD 1
profile.country.pt_PT.title
V57...
Salut caneves51,
Peut-être ça peut vous aider...
Diagrammes de connectivité
Reliez vos produits de façon optimale
Remarque : certains documents ne sont disponibles qu'en anglais
This guide is intended to help you understanding high definition home entertainment and connecting your audio and video devices the best possible way
Connect your High definition devices Connect your Standard definition devices Connecting the computer to the television set
High Definition vs. Standard Definition
Standard definition (SD) videos (i.e. NTSC, PAL, SECAM) are signals of a resolution between 480 and 576 horizontal lines.
High definition (HD) videos are signals of a resolution between 720 and 1080 horizontal lines.
You can compare HD and SD to digital photography: a 10 million pixels picture printed on a 10x15 cm paper will not look much better than a 5 million pixels picture printed on the same format. However, if you print the same pictures on a 40X30 cm, the difference will be huge.
On a small display, you will not necessarily see the difference between both. You may notice a difference in colours only, as the colour gamut of high definition pictures is wider.
However on a larger screen (from 32 inches with at least 720 horizontal lines or vertical pixels), the difference becomes very noticeable.
SD picture on small screenHD picture on small screen
Standard definition on a large screen
High definition on a large screen
Before connecting your devices...
At the back of your video and audio devices, you may find the following connectors, depending on the model you have:
Name*AspectQualitySignal transmitted
HDMIHDMI*****picture + sound
DVIDVI*****picture
Component videoCOMPONENT****(*)picture
SCARTSCART**(*)picture + sound
S-Video**picture
Composite video*picture
Digital Coaxial*****Sound
Digital Optical****(*)Sound
* For each connection type, a colour is used to make the diagrams easier to understand.
To enjoy the best audio visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.
Note : the quality of the picture also strongly depends on the quality of the cable used.
HDMIThe High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV)
DVIThe Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA).
It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter
Component videoComponent video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA)
SCARTThe SCART connection is a European standard that gathers together various common analogue signal types such as RGB, S-Video and Composite into a single connector. It can transmit standard definition sound and video. However the picture quality is inferior to HDMI, DVI, and component video. It can only transmit standard definition signals
S-VideoSeparate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. This connector is not represented in our connectivity diagrams
Composite videoComposite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in term of quality. This connector is not represented in our connectivity diagrams
Digital coaxialDigital coaxial connector carries compressed digital audio. This type of connection can transmit stereo and multi channel audio data in various compressed formats like DTS, Dolby Digital etc. It looks similar to a regular RCA audio cable, with the exception that its impedance is of 75 ohm and that it is made of a thicker shielded cable.
Note: A Digital coaxial connection cannot transmit the new HD sound formats like DTS HD, Dolby True HD etc...
Digital opticalDigital optical connector has the same functionalities, except that the signal is carried through optical fiber.
Note: A Digital Optical connection cannot transmit the new HD sound formats like DTS HD, Dolby True HD etc
Connect your devices
Cordialement
