sony wh-1000xm4 volume to low
soksyA6000
New
HI bought these headphones to go with a Fiio DM13 portable CD player and the sound when I have the cable in is very good for the volume, but when I try Bluetooth I have to put the volume on the CD player up to 99 to get any volume, and It's still too low what can I try to have tried a cheap pair of Motorola headphones and these are OK with good volume coming out of them The headphones are brand new.
2 REPLIES 2
TheGOAT
Hi @soksyA6000,
I believe it might be a compatibility issue as your other device must support A2DP Bluetooth profile. However, you can try these steps:
antonioN
New
I also use these headphones with my Fiio and had this problem. I solved it by turning up the volume on the player itself and turning it down on the headphones. If that doesn't help, check the Bluetooth version on your Fiio - older versions may not support good sound.
