- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hope someone can help. Started to charge my PRS-505 and after some time the charging screen appears and continues to charge. Then the reader changes screen to 'starting up' and hangs there forever. I have tried re-setting it but I think I am not doing it correctly. NB Whilst on this screen I get no reactions to any butons pressed including power o/off.
Thanks in advance
Alan
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Don't know much about the 505 I'm afraid, but I'm presuming you've had this a while - and you are following the manual's procedure on resetting ?
If you have a hard/soft option, a "hard" reset may be needed - but remember to back-up all contents, as you will lose everything on the device, so you can load them on again.
Another possibility may be the battery - it may have reached RIP time
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
