Help needed
SOLVED
myscribbles
Help needed
My e reader PRS 600 is 2 years old but has never been used. I recently charged it via the computer and loaded some books, then played around with resizing etc. It then was low on battery, so I attached it to the computer for 5 hours. Now it says it has no battery!  Help!
1 ACCEPTED SOLUTION
Accepted Solutions
sehuxle
Try charging it via a USB mains adaptor. Leave it to charge overnight.
But it may be that as its not been used for ages the battery is, to use the technical term, buggered
2 REPLIES 2
sehuxle
carpetmojo
:smileylaugh::smileylaugh:
Can't stand all these technical terms meself...............:smileycool:
