DSC-TX5 Battery Indicator Hidden?
nokungfu
I recently bought the Sony DSC-TX5 and it is a fantastic little camera. The only issue is I can't get it to display the battery indicator. I know it should display in the top right corner above the media storage indicator, but there is nothing there. I haven't found anything in the settings or manuals to suggest you can turn the indicator on/off.
Can someone point me in the right direction? It's quite frustrating not knowing how much battery life you have left, even if it is just an approximate.
5 REPLIES 5
StartTheCar
Contributor
Hello
Just spent the last hour going through every menu and setting on this product and, like you, I can see no way to turn off or hide the battery indicator.
Can I ask if you are using the supplied battery?  Also, do you have another battery you could try?
Regards
Lee
nokungfu
Hi Lee - yep using the supplied battery and don't have another battery to try. I might try cleaning the battery's terminals in-case that has any effect but I doubt it will.
Stumped.
StartTheCar
Contributor
I tried again this morning and no matter what I did I could not make the battery indicator disappear.
Logic and experience suggests it’s related to the battery.  If you can send me a PM with your contact details I can give you a call, e-mail about how we can sort this out.
Best regards
Lee
fragaeder
New
Hi guys!
So, i have the same problem with my TX5.
The battery indicator is hidden.
Did you resolved this problem?
Regards
I have this same problem with the A33. Can't figure it out
