How do you put the date on your pitures, when the date is already set? I would like to print the pictures with date on them?
Solved! Go to Solution.
Hi cath..111 and welcome.
To print the date & time on your pictures, you need to use computer software as this information is held in the EXIF file and not in the image itself..
The PMB software provided with your camera will allow you to do this - have a look at Page 65 of your manual here: -
http://pdf.crse.com/manuals/4126517111.pdf
There is a tutorial here: -
http://www.sony-mea.com/support/faq/365648
