I have the handycam above. The inbuilt sound is not always as good as I'd like when I am a few feet from the object I am recording and in a noisy environment. Especially when recording someone speaking.
Could someone more knowledgeable than I please advise if they know of good solutions (lapel mike, directional mike etc) that are suited for a more 'budget' pocket, but not necessarily a budget sound!
Any replies appreciated.
Hi there BGDwth,
I am not familiar with the camcorder you listed.
If it has a 3.5mm microphone jack, you should be able to use any microphone with a TRS (Tip Ring Sleeve) connector. Beware of TRRS connector microphones, since they won't work with a default audio jack.
I had very good experiences with so called "shotgun microphones" in situations, like you describe.
The record a "cone" in front of them, nearly nothing to the sides, nothing behind.
- Nic
Hi Nic
Much appreciated for the reply, thanks, I'll look into those options.
BGDwth schrieb:
Hi Nic
You're very welcome.
Probably too late, but maybe useful for someone else.
Record the sound separately and then sync it to the video in your editor. You will need a mediumly decent editor to do it. I use Kdenlive (free) in Linux and CyberLink PowerDirector (paying) in Windows.
So, do you need a new recorder? Most probably not. If you have a smartphone, you have a recorder. Put it in some pocket on your subject and film him/her from far away. The sound will be quite good. There are some very cheap smartphone lapel microphones but even corded hands-free earphones can be used as such.
