Sony Handycam DCR-PC1E download to PC
SOLVED
GerrytheMole
Hi, I have a Sony Handycam DCR-PC1E and want to download the footage from the tape to a PC for editing.  I have the connecting firewire cable, but what next? Cheers
1 ACCEPTED SOLUTION
Accepted Solutions
GerrytheMole
Hi, after digging around a bit I think I can answer my own question, posted here for the benefit of the community.
With the mini-tape in the camera I attached the firewire cable from the handycam (camcorder) to the PC and turned the handycam onto ‘Player’ as if I was going to watch playback actually on the handycam.  Suddenly the handycam burst into life and Windows Movie Maker fired up on the PC, great.  From there on it was pretty plain sailing you just use the Windows Movie Maker to ‘Capture from video device’.  You give the file a name and a location to copy it to and It automatically divided the file into clips. Editing in Windows Movie Maker is quite straight forward, not that I am an expert and then save the project.
I think I like this, looking forward to many happy hours editing.
Cheers
Gerry the Mole
7 REPLIES 7
GerrytheMole
Cheers
Gerry the Mole
MANDIA
New
Hi, I know its a longshot as this is quite an old post now, but would be grateful if you could help me out!
I have a Sony Handycam DCR-PC1E and read that you were able to transfer these onto your computer using a firewire cable.  I haven't got one of these at the moment, but I've seen some I can buy on the internet.  If I buy a 4 pin data cable with a USB at the other end, will I be able to download to my laptop?
Marino.Manolo
I don't think so... Probably with an FireWire to USB cable your laptop will can see your Handycam but will can't transfer the videos...
You have to buy an external FireWire "Capture Card" with USB connection for the connection to laptop. If you have an ExpressCard slot in your PC's you can buy this one in FireWire version...
FireWire female connector's is 4 Pin in you Handycam, in the Capture Card / ExpressCard probably the female connector is 6 Pin (for power, but you don't need) so, you can to buy a cable FireWire from 4 Pin to 6 Pin or an adaptor 6 Pin > 4 Pin...
Sorry for my poor english...
Manolo
MANDIA
New
Thanks for the advice Manolo, your English is excellent! It's my technical knowledge that is lacking!
Sent from my iPhone
mabsmo
New
Would you have a link to where I can purchase:
1) the firewire cable
2) the firewire PC adapter
I am UK based.
Thanks
Tags (2)
profile.country.EE.title
Wellray
New
Hi there,
I've a Sony DCR PC1E and I have the dv cable 4pin to 6pin, however neither my macbook or iMac has a 6pin port - they have different thunderbolt versions, HDMI, and USB 2 so I'm trying to find a cable with dv to one of these that will allow transfer from the cassette. Any ideas?
Thanks
Ray
TheGOAT
Hi @Wellray,
You can use a combination of adapters and cables to connect the DV port to your computer's Thunderbolt, HDMI, or USB ports. Here are a few options:
  • Apple Thunderbolt to FireWire Adapter: This adapter allows you to connect your 4-pin to 6-pin FireWire cable to the Thunderbolt port on your Mac.
  • FireWire to USB Adapter: These adapters can convert FireWire to USB, but they may require additional software or drivers to work properly:
  • Video Capture Device.
