I have now tried to get PMB to work for 3 years. On multiple operating system versions and multiple PCs. I have tgried on PCs where I have not installed Photoshop - which I suspect uses CODEC PMB can't handle.
Installed the latest version this morning - and now it crashes even faster!
I have never tried a program like this.
Best way is to install original version PMB but, on PC deinstall codec packs all...like K-lite ect. it can realy disturb. Reset PC and install latest firmware update for Your grafic cart. Turn of sicurity program like fire wall when installing PMB if needed.
Do you use PMB for a AVCHD Sony videocam?
I have used it for three years without any problem what so ever,
except it does not run under Win 7 32-bit.
Win XP and Win 7 64-bit is perfect.
Peter
