Please tell me the process to exit from safe mode for Xperia c3 dual mobile
I reboot the phone. But still it can't exit from safe mode
Thank you @ganeshm for your quick reply!
In that case I suggest that you make sure that the volume down key is not pressed during startup.
if your phone has a protective case, remove it, as it might be pressing on the volume keys that could be causing the phone to reboot to safe mode.
Let me know if that helped!
