why does my bravia kd32w800p1u not have the facility to scan for analogue channels
dougbosley
New
2 REPLIES 2
daveyh64
Contributor
What do you mean by analogue channels?
If you are in the UK analogue broadcasting was switched off in 2012 when the digital switch over was. completed.
How do you receive channels on your TV at the moment.
See the path below, this is how I select which way my TV receives broadcasts, I have a different Sony TV to you
so the path for yours may be slightly different.
Settings (remote control) > Settings (on screen)> Channel & Inputs> Channels> Channel Set Up
select either Auto tuning or manual tuning and from there you will be asked which way you receive channels,
either through aerial, cable, satellite or analogue.
Your TV has tuners for digital, satellite and cable broadcasts, it also has an analogue tuner but as I say that is redundant in the UK.
royabrown2
Hero
@dougbosley
Oh, but it does:-
TV System (Analog)
  • B/G,D/K,L
Stick an old VHS (or as it’s Sony, Betamax) recorder in the aerial chain, start it playing something, and the analogue scan will find it.
But, as others have said, there’s no national, or even local, analogue broadcasting still going on.
