Voice activation
Voice activation
Since broadband was upgraded to Halo 3 my voice activation on 2 TVs doesn’t work
2 REPLIES 2
LightFoot
Specialist
Hi @Jaslock1602
Assuming BT Halo 3 then this is just an add on benefit and not a change of broadband. Has something changed like you have moved to Complete WiFi and now have a BT Smart Hub 2?
In which case it is recommended that you turn off Smart Setup and connect your TVs to your new router.
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Joe_Dohn
Specialist
@Jaslock1602 I agree with SonyUser30Yrs, but could you also share the model number of both TVs you're referring to?
