Audio level on sony tv bluetooth output to my sony headphones very low (indicated setting 98) compared to output level from headphone socket (indicated setting 22) I have varied out factory resets on tv and headphones numerous times
Sony tv MODEL No. KD - 43X8305
Serial No. 6706545
Sony headphones MODEL No. WH-1000XM4
Is it possible that it's not an original one because the model is missing a letter?
@Bernardus37 Try to check the model from the settings first, also where did you buy it from?
