Unable to register external HDD on KD-55XG95045
joporte87
Connect ITB to USB REC port. I can see it in Storage and could format it from there but I want to record programmes on it (some say disable YouView app first - I have tried both). There is no option to register the drive for recording. Any ideas?
3 REPLIES 3
Piscie
You need to make sure that the HDD device is compatible with your TV for recording. Take a look on this link it might help you to fix this issue: https://bit.ly/3rqnK2L.
joporte87
Thank you. I have followed all those steps (it is compatible) and the ones in the troubleshooting guide. Issue persists.
Piscie
What is the current software version? It also seems that the model number is incorrect, are you sure from this model ?
