Sound issues through optical
SOLVED
profile.country.LV.title
u60js2
I have a KD-65XF9005 and have some issues with the optical out to sonos playbar.
What works:
DD 2.0 / DD5.1 from HDMI sources (Sky Q and BluRay player)
DD5.1 from TV apps (Amazon and Netflix)
What doesn't work:
Anything that is not DD 5.1 from TV apps (Amazon / Netflix)
Basically the only issus is when trying to watch something from Amazon / Netflix which does not have a DD 5.1 audio track. I have tried different audio settings (Auto 1 / Auto 2 / PCM) but non of these make a difference.
This is strange bahaviour, most people seem to have a problem trying to pass DD 5.1 but I have the problem where I cannot pass anything from the TV apps which is not DD 5.1.
I have compled a system update but no solution.
Has anyone experienced the same issue or know of a solution to this problem?
Thanks in advance!
J
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there,
Have you tried a factory reset?
Best wishes,
M
3 REPLIES 3
Anonymous
Not applicable
Hi there,
Best wishes,
M
u60js2
yes a factory reset solved the problem.
Thanks
Sean_Mc
Moderator
Hi J,
Thanks for letting us know this has resolved the issue for you.
Best wishes,
Sean Mc
