Sony Bravia XR55X90J LED HDR 4K Ultra HD Stands
paulbristow
I had the TV installed by John Lewis and the TV appears to slope slightly to the back, I believe they have put them the wrong way around, before I attempt to alter them, can they be removed as there are no screws due to them clicking in. Will they unclick?
4 REPLIES 4
paulbristow
Guess no one knows as no replies
Joe_Dohn
Specialist
They should be removable normally, you can follow the Startup Guide for your specific model. That said, some models are supposed to be leaning slightly backwards, even though I couldn't find this specific model listed, but it might be that the article wasn't updated?
Hope this helps!
- JD
paulbristow
Thank you for the reply have already looked at the start up guide unfortunately it only shows clicking them in, no mention that they can be un-clicked.
Joe_Dohn
Specialist
I was referring to the Startup Guide so that you can do the reverse of what is shown, they never show taking it apart for simplicity's sake.
That said, they are definitely removable since your TV supports 2way position (Standard position/Narrow position) according to the Design section of the specs.
Hope this helps!
- JD
