hi guys, I have got this TV a bit less than a year ago. The problem with the wifi isn't new, but it drops increasingly often nowadays. I sometimes have to fix it manually every 5-10mins, which is quite annoying
Every time it happens, I figured there are 3 ways to "fix" it: 1. long press the On button on the remote to reboot the TV, 2. reboot the wireless router, 3. go into connection setting, forget the network and then re-connect to it by re-entering the password (the fastest way among these 3).
I have checked and verified that the connection issue is only with the TV, as I could use my other device such as IPad and computers without connection issue at the time when the connection drops on the TV. I can confirm that the automatic update for on and the software is up to date. Also, my wireless router is literally only 1 meter away from the TV, so I don't see how I can put them even closer.
Does anyone have the same issue?
Thanks.
Hi there
As you are probably aware, all sorts of things can interfer with Wifi connections, including other electronic equipment. As your router is "literally only 1 meter away from the TV" - why not just use an ethernet cable? You will get a much more stable connection.
Cheers
Because it looks ugly and therefore even if I can bear with it, it won't be an acceptable solution for my wife unfortunately..
