My Dony Tv Bravia model no KD-43XH8096
Uniquez
New
My TV does not connect to the remote.  Changed battery still was not connected then decided to buy a new remote but the problem remains the same.  The TV function perfectly fine.  Can you all help me please what should I do?
Thanks
2 REPLIES 2
daveyh64
Enthusiast
First have you checked to see that both remote controls are emitting a signal using your camera phone.
Switch the camera on the phone and point the signal end of the remote at the camera lens, press any button o
n the remote and if you see a light on screen the remote is fine.
When you point the remote(s) at the TV do you get a confirmation flash of the LED on the TV as it picks up the
the signal from the remote(s).
If the TVs LED does not respond to any buttons pressed on the remote(s) it would indicate that the Infra Red receiver board on the TV has failed. Unfortunately on such an old TV a repair would be financially unviable.
So do you fancy a new telly?
Uniquez
New
Good morning daveyh64
Thank you for getting back to me.
So first of all, I have read the instruction given below but am not sure if have followed this information correctly especially on the first part about 'remotes emitting signal'.  As I didn't see anything.  However, I can see a flashing light on my new remote.
Also, there is no LED flash on TV as the TV itself does not respond to any button I press on my new remote.  But it responded only once on my old remote when I switched on the TV.  But when I tried to  switch the TV off/press other buttons , there was no flashing lights shown.
Yes! I would love to have a new TV but not at this moment.  I only had this TV for 3 years and 5 months.  So,  I never thought I would experience such problem at this early stage.
