kd55xg8196 Sony MediaTek api fix
dedge_10
updated to the latest firmware v6.6520
I am trying to get Dolby + Atmos to play through Kodi and Sony's built in video player
been on so many forums.
Sony's built in video player is well slow especially when using unpn some time's over a minute to connect then when it does I get, can not play this file etc.
please fix SONY
6 ANTWOORDEN 6
Pascale_F
Moderator
Hi dedge_10,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
rooobb
Your tv specs do not include Dolby Atmos, why do you expect it to work?
dedge_10
It is running through A Yamaha RX-v585 RDS amp
watching Netflix etc is fine
rooobb
Your Home Theatre can decode Dolby Atmos, but your Tv not. So if you are running an app on it, it would not be able to pass it to the receiver
dedge_10
I enabled Dolby + in the tv setting
install Kodi and play dolby-atmos-trailer_leaf_1080p.mp4
and I get Atmos
it's only the sample and Netflix, amazon I get atmos anything else I don't, usually  MKV  I struggle with
Dolby Atmos can be delivered by Dolby Digital Plus
Format/Info              : Enhanced AC-3 with Joint Object Coding
Commercial name   : Dolby Digital Plus with Dolby Atmos
Codec ID                    : ec-3
Duration                    : 59 s 297 ms
Bit rate mode            : Constant
Bit rate                       : 448 kb/s
Channel(s)                 : 6 channels
Channel layout          : L R C LFE Ls Rs
Sampling rate            : 48.0 kHz
Frame rate                 : 31.250 FPS (1536 SPF)
Bit depth                    : 16 bits
Compression mode  : Lossy
Stream size                 : 3.17 MiB (5%)
Service kind                : Complete Main
Default                         : Yes
Alternate group          : 2
Encoded date              : UTC 2018-05-03 17:08:01
Tagged date                 : UTC 2018-05-03 17:08:01
Complexity index         : 16
Number of dynamic objects   : 15
Bed channel count        : 1 channel
Bed channel configuration   : LFE
The_Black_Rose
Specialist
Hi Dedge_10,
Regardless of the external device connected, since your TV doesn't support Dolby Atmos, the content will not play in Dolby Atmos.
I checked the specifications of the TV and found that it only supports Dolby™ Audio(Dolby™ Digital, Dolby™ Digital Plus)
Cheers,
The_Black_Rose
