Recently purchased a KD-55XH9005 and overall please with the TV, however there is 1 annoying issue that if i can resolve will result in me returning the TV.
The issue is the Subtitles always defaulting to on for 1 channel only, the setting is turned off and is fine with all other channels.
The 1 channel causing an issue is BBC One HD on Freesat, anybody have any ideas as to how turn this off?
Thanks in advance
Hey MentionedOllie, did you try the steps on the thread? They worked with many users. And BTW, this is a user based community, if you want you can contact Sony directly.
I have a similar issue with subtitles being activated in the YouTube and Netflix apps.
Sometimes starts straight off but also activates at random times.
Yours is not really a similar issue, all previous posts in this over 3 year old thread has to do with Freesat.
Yours seems to be with streaming services.
Try starting a new question rather than tagging onto old posts, you are probably more likely to get
a response.
When composing your question include information such as the exact model of Sony TV you have
and the version of software it is running.
If it is question about subtitles on streaming services what are the settings you have applied to the
Streaming and other content subtitles options. under,
Settings> System> Subtitle settings> Streaming and other content.
Do the apps in question have separate subtitle options?
