I purchace a Sony Bravia 49" tv around 12 months ago.
The Brightness & Contrast are on MAX & still the picture is dark. Is there anything i can do to correct the situation.
Thanks. Colin.
Which content on which tv model are you watching?
If it’s an LCD set, try upping the backlight.
But if it is an OLED, it won’t have this.
Other than that, make sure the picture is Vivid rather than Eco, and go through the settings for Picture, including the advanced ones, disabling anything that looks as if it might cut your brightness down.
Basically, if you maximise any setting that brings up an annoying pop-up to say you are wasting electrons, you are on the right track.
If still dark, disable any HDR, Dolby Vision, and so on that you might have.
@royabrown2 you are suggesting to set the tv to alter the content and get a sun bath
, but if it is what the guy is expecting you may be rigth
If you mentioned the model number of your TV, we can help you with various settings to adjust
