Android tv won't turn on from standby mode
sunseeker247
hi I am hoping someone can help I have a Sony android TV that I turn off with the remote using the green button EXT box menu which puts the tv into standby mode, when I get up the next day and try and turn the TVs on with the same button it does not come on, to get the tv to come on I have to turn the switch off where the plug is wait 10 seconds then switch it back on, then when I press the green button but it always reboots the tv which is not ideal, does any one have any suggestions ?
7 REPLIES 7
khallergard
Have you tried removing the device in your usb port before switching to standby?
khallergard
@sunseeker247  Any progress?
profile.country.GR.title
trospeg4
Hi All,
Just for the record.
I face the same issue with a KD-49XG8096 android TV, it happens randomly, once every 2-3 weeks.
Thank you.
Tags (1)
khallergard
@trospeg4  Did you try the usb remove tip?
trospeg4
@khallergard yes I removed the USB dongle yesterday and will see if the issue reoccur in the next few weeks.
Thanks for the tip!
khallergard
My problem started after upgrade to Oreo 6.6510.  As i realized that the RF dongle was the culprit, I switched to a bluetooth mouse.  Recently I received an ota update to Oreo 6.6545.  Tested for a few days with the RF dongle in wjth no problems.
trospeg4
Just wanted to let you know that the USB dongle removal tip seems to solve the issue. For over a month now issue not occurred.
I will order a Bluetooth mouse instead.
Thanks for the tip @khallergard :slight_smile:
