How do I disable this
So annoying when it regularly pops up
Opgelost! Ga naar oplossing.
Hey Paul, try fcookes's solution, obviously this is not an issue with the TV itself.
When I turn it off then Netflix, Prime, YouTube don’t work
Mine started doing this 2 weeks ago after I switched from Plusnet to Now broadband. No problem in previous 2 years…..
2.4 and 5 are both on by default
there is no power save function on the router….
Thanks but it doesn’t apply to the Sky/Now router and Ethernet is not an option.
