Sony A7s3 and the XLR-K3M, 4 x inputs or just 3?
Reelyreel
Hi all,
I have both these products, written above in the subject.
Is there a away to plug in 4 x radio mics in to the camera
I have managed x 3
I have achieved this by....
2 radio mics via XLR on K3M
1 radio mic through the mini jack port on K3M
I have a spare channel on the A7s3 spare but cannot add a 4th is this impossible?
Is there a way to input 4 or is the '3' in K3M the give away and it's just 3?
Please share as I know the camera can record 4 audio channels.
I have 4 x channels on camera to use but can only use 3.
Is there another way or can the K3M work with a splitter perhaps?
Many thanks
5 REPLIES 5
Hi Reelyreel,
According to the specs of the XLR-K3M the 3rd input is a stereo input. So you should be able to connect 2 microphones by using a Y-adapter.
Cheers
Peter
Reelyreel
Hi Peter,
Y adaptor, splitter, do Sony make this product, if so, could you share the product code?
Thanks again for all your help!
Joe_Dohn
Specialist
Hi Reelyreel,
I don't think Sony makes dongles, adapters or splitters any more (if they had before, not sure).
I'd recommend checking your nearest camera/computer shop for a recommendation.
- J.D.
Reelyreel
Hi Joe,
I have found a third party mini jack splitter.
Thank you for your reply.
dsol1980
New
Hi!  now that you've been using this - can you tell me if this is recording to 4 channels of audio on the physical file, or if it's simply mixing the inputs down to 2 channels of audio (a traditional stereo file connected to the video file)
