"This accessory is not supported by the device and cannot be used."
darthpapimus
New
I've had my Sony A6000 since 2015 and yesterday started getting this message when I power on:
"This accessory is not supported by the device and cannot be used. Please verify the compatibility with the device."
I haven't added any new batteries or SD cards, same as before. I don't use the hotshoe either. Any suggestions to fix? It's getting annoying and intrusive.
Tags (1)
3 REPLIES 3
Joe_Dohn
Specialist
Have you tried removing the battery and memory card for a few minutes? If it's an issue with a terminal misreading or "ghost-reading" an accessory, that should be enough to solve it.
- JD
darthpapimus
New
I took them both out for an hour and put them back in, but the message came back about 30 seconds after powering on.
Bat_Rick
New
Did you try to use another SD card?
