Hi Everyone
I feel so stupid! I'd forgotten to switch the SD/Memory to SD.
Thank you all for assistance which I know would have been given.
Regards
Norfolklad
:smileygrin: No probs - thanks for letting us know!
Cheers
Mick
I have the exactly same problem and I am not sure how to resolve it, because I am not finding to SD swich (?) whatever taht is. Could you please let me know how to do this?
Thank you so much!
HI, Do you happenes to know what can be the problem with the "no card" "reiser card" on the LCD. I am very frustraited and dont know what to do?
Thank you for your help!
Helga
You "might have" switched the camera on and then pushed the SD card in whilst the card slot was live. You need to switch the camera off, prior to insertion, or withdrawal of SD car, or of the battery.
Few things you might like to try :
1) reformat the card to ordinary FAT [16bit], not to FAT32
2) insert the card and and the fully charged battery in and switch the camera on. Leave it switched on for 10 minutes. If that doesn't cure the problem?
3) repeat the above procedure (as per item 2), but at the end of 10 minutes waiting time, pull the battery out, whilst the camera is switched on. Wait for 2 minutes, then switch the camera off. Then reinsert the battery and switch the camera back on. The camera will go through the hard reset procedure and hopefully liven up the card slot in process. You might have to check and reset your menu as well.
Hey wondering what you did to solve this. I saw your message saying you switched the storage to SD but I'm not sure what that exactly means.
Mind walking me through a step by step?
Lots of cameras allow hot-swapping cards - all my Sony cameras do (alpha 57k, CX130E, AX100, AS100, AZ1, X1000, X3000).
Some Sony cameras allow MemoryStick Pro Duo storage medias as well as SD cards, so the card-slot is made in a way, that you can put both cards in either way round, while each type is only readable by the camera in the correct orientation.
Another issue could be, that the SD-cards "read/write" switch on the side is switched to "lock".
- Nic
I have followed the procedure descripeded by rcjenn but the camera still says "no card"
the camera is Sony DSC-HX400V and I can't find any possibility to switch the SD card on or off.
Also I have tried to find a discription in the manual for an external media connection but I cant fond any
