Download & Help Installing Firmware
SOLVED
Norfolklad
Dear Friends
I'm in a bit of a muddle!
I've downloaded an firmware update for my Alpha a230 Digital Camera but I'm just so confused as I don't seem to be able to open this or install this. I'm currently running Windows XP.
I tried to follow the information on the Sony website but this just doesnt work for me. The file that I have for this is as follows:-
DSCA230V110.exe
I re-formatted my SD card and uploading this to the camera but to no avail. Please could someone possibly give me a step by step guide how to do this as I'm not very good with computers or camera's really and don't understand what I have to do.
Many thanks to anybody who might be able to point me in the right direction
Regards
Norfolklad
Message was edited by: Norfolklad
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
You should have downloaded the firmware update version DSCA230V110.exe to your PC.?
Once downloaded browse to the location you saved the DSCA230V110.exe file & double click it.
Click Run if requested to do so & wait for the file DSCA230.APP to extract.
Next make sure you have inserted & Formated your SD card in the camera. (see below if unsure how to)
  1. Turn  OFF the camera power, then insert the prepared recording  medium into  the camera. Ensure that the memory card switch is on the  side of the  inserted media.
    Sony
  2. Slide the POWER switch to the ON position.
  3. Press the MENU button to display the menu, select  Sony the Playback menu-1       using the Control buttons.
  4. Select the "Format" in Sony the Playback menu-1 with the Multi-selector then press the Center button of the Multi-selector.
    Sony
  5. The confirmation window appears. Select [OK] with multi-selector, then press the Center button of the Multi-selector.
  6. After the format is completed, press the MENU button to turn off the menu.
Then copy DSCA230.APP to your SD card. (note do not place this file into any folder on the SD card)
Then follow the guide below..(note important points below BEFORE starting the update) Also if your using a SD card ensure the switch in point 1 is set correctly..
Important: When performing the firmware  update, use fully charged rechargeable battery pack NP-FH50 or the AC  adapter AC-PW10AM (sold separately).
Do NOT remove the battery or the AC adapter during the firmware update process, otherwise the camera may be permanently damaged.
    SonySony
  2. Press the MENU button, and turn ON the power while still pressing the MENU button.
  3. When  the following confirmation window appears, use the control button to  select "OK", then press the center of the control button to confirm the  selection.
    Sony
    If the confirmation window does not appear on the LCD monitor:
    • If the recording medium is not formatted, the firmware update may not start.
    • Please make sure that the update file (DSCAxxx.app) is in the root folder of the recording medium.
  4. The updating procedure will start, and the following screen will be displayed.
    Sony
  5. Do not turn off the camera until the updating procedure is complete. (Update will take approx. 30secs)
  6. When  the firmware update is complete, the following screen will be  displayed. As the camera will automatically restart after approx. 10  secs, please wait for the camera to restart.
    Sony
  7. After  the camera has restarted, turn OFF the camera, and remove the recording  medium. Next, check that the camera firmware version has been correctly  updated.
4 REPLIES 4
Thalamus.
Champion
Hi Norfolklad,
welcome to Questions & Answers..:smileyhappy:
First thing to check is does your A230 already have the latest firmware version installed, to Check follow the instructions below:
If the firmware version is already Ver.1.10, it is not necessary to update the firmware.
Sony
  1. Turn ON the switch of the camera power
  2. Press the MENU button to display the menu
  3. Select Tab 3 of the Setup Menu using the horizontal buttons of the control button
  4. Select "Version" by pressing the down button of the control button
    Sony
  5. Press the center of the control button
  6. The firmware version will be displayed on the LCD monitor
    Sony
  7. Press the center of the control button to close the version display
Norfolklad
Hi Thalamus
Thank you for your help on this.
I've already checked this part and it states that I have Version.1.00 but according to the Sony Website there is a newer version. I've already downloaded the Firmware Update but can't seem to work out how to get this onto the camera.
I've followed the instructions on the Sony website but it doesnt seem to work for me in updating. I don't understand what I'm doing wrong.
Thanks for any further help if possible.
Norfolklad
Thalamus.
Champion
    Sony
    Sony
    SonySony
    Sony
    Sony
    Sony
Norfolklad
Hi Thalamus
Thank you so much for your kindness and patience with me regarding this Firmware question.
I'm not very good with technical things unfortunately especially where computers are concerned . Regretably I'm still not able to open this file, do I need anything running on my computer to open this as I've got a box saying that:-
Windows cannot open this file:
DSCA230.APP
To open this file, Windows needs to know what program created it.
I'm still trying to figure out what I now have to do. Please may I ask if you perhaps know what it is that I should be rrting now.
Many thanks again for all your help
Norfolklad
