I have taken movies before in Florida and have never had this problem. On Saturday, when the ambient temperature was below average and I had been recording for about 8 minutes, I suddenly had the recording stop with the error message ' camera overheating' appear on the screen. I switched off and left it a few minutes and then took some stills and the camera worked O.K. Any suggestions ?
Solved! Go to Solution.
This is a known issue and common to most DSLR cameras to some degree or other when shooting movies or continuous still images. However, the in-camera steady shot adds to this heating in Alpha cameras as power is being used to constantly move the sensor to counteract camera shake.
Sony have released a guide which would appear to agree with your observations - at 20 degrees the continuous shooting time is 9 minutes with SteadyShot ON and 29 minutes with steadyshot OFF. This time decreases rapidly at higher temperatures.
Have a look at this Sony link: -
http://esupport.sony.com/US/perl/news-item.pl?news_id=424&mdl=SLTA33
Many thanks for that information and promptness of your reply, your expert knowledge is very much appreciated.
If you are trying to squeeze every last second out of A55 or NEX film recording times then raise the LCD screen.
