Can someone explain this phenomenon to me? When I attach a non-autofocus lens to the Sony Alpha 7R V, turn on manual focus and zebra mode on the camera, everything works as with the native autofocus lens in manual mode. But when I try to start the Focus Magnifier mode, the following appears on the display: "The lens is not attached correctly or is not supported!"
Does this mean that Magnifier mode on the Alpha 7R V camera does not work with older, simple non-autofocus lenses?
Maybe I didn't make all the settings? (I hope)
Be sure you are trying to use Focus Magnifier
https://helpguide.sony.net/ilc/2230/v1/en/contents/TP0002887713.html
and not Auto Magnifier in MF
https://helpguide.sony.net/ilc/2230/v1/en/contents/TP0002911175.html
If it still doesn’t work, probably it’s a functional limitation (that I can’t understand 😞 )
