I was using XZs for the past 2 years with gaming mode on while game to stop pop out message.
Are there same or similar function in Xperia 5?
Solved! Go to Solution.
Hi @SamNg,
In the Xperia 5 when Xperia actions aren't available, you have a detected application called "Game Enhancer". For the games that supports this feature, you have something called "Focus settings" where you can turn off notifications, incoming calls and so forth.
There are also some new settings, such as release RAM, lock the navigation bar, disable side sense , record the screen if the game supports it and so forth.
https://support.sonymobile.com/global-en/xperia5/userguide/game-enhancer/
I hope that answers your question!
Hi @SamNg,
