Two attempts were made to unlock the bootloader of my Xperia 10 III(XQ-BT52) in order to install "Software binaries for AOSP Android 11.0 – Kernel 4.19 – Lena (latest)" via Ubuntu and Windows 10 respectively. The official guide on unlocking the bootloader of Xperia devices was followed entirely in the Windows 10 attempt, though source for the Platform tools differed in the Ubuntu attempt.
Both attempts resulted in an identical error when executing the final command:
fastboot oem unlock 0xXXXXXXXXXXXXXXX
FAILED (remote: Command not supported in default implementation)
finished. total time: 0.00
Below is record of the process from initial setup to the final error during the Ubuntu attempt:
ubuntu@ubuntu:~$ sudo apt-get install android-tools-adb
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
adb android-libadb android-libbase android-libboringssl
android-libcrypto-utils android-libcutils android-liblog
android-sdk-platform-tools-common
The following NEW packages will be installed:
android-sdk-platform-tools-common android-tools-adb
0 upgraded, 9 newly installed, 0 to remove and 163 not upgraded.
Need to get 862 kB of archives.
After this operation, 2707 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-liblog amd64 1:8.1.0+r23-5ubuntu2 [41.9 kB]
Get:2 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libbase amd64 1:8.1.0+r23-5ubuntu2 [22.4 kB]
Get:3 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libboringssl amd64 8.1.0+r23-2build1 [538 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libcrypto-utils amd64 1:8.1.0+r23-5ubuntu2 [8324 B]
Get:5 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libcutils amd64 1:8.1.0+r23-5ubuntu2 [22.5 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libadb amd64 1:8.1.0+r23-5ubuntu2 [123 kB]
Get:7 http://archive.ubuntu.com/ubuntu focal/universe amd64 adb amd64 1:8.1.0+r23-5ubuntu2 [87.6 kB]
Get:8 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-sdk-platform-tools-common all 27.0.0+12 [6648 B]
Get:9 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-tools-adb all 1:8.1.0+r23-5ubuntu2 [11.0 kB]
Fetched 862 kB in 3s (299 kB/s)
Selecting previously unselected package android-liblog.
(Reading database ... 190714 files and directories currently installed.)
Preparing to unpack .../0-android-liblog_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-liblog (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-libbase.
Preparing to unpack .../1-android-libbase_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libbase (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-libboringssl.
Preparing to unpack .../2-android-libboringssl_8.1.0+r23-2build1_amd64.deb ...
Unpacking android-libboringssl (8.1.0+r23-2build1) ...
Selecting previously unselected package android-libcrypto-utils.
Preparing to unpack .../3-android-libcrypto-utils_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libcrypto-utils (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-libcutils.
Preparing to unpack .../4-android-libcutils_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libcutils (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-libadb.
Preparing to unpack .../5-android-libadb_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libadb (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package adb.
Preparing to unpack .../6-adb_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking adb (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-sdk-platform-tools-common.
Preparing to unpack .../7-android-sdk-platform-tools-common_27.0.0+12_all.deb ...
Unpacking android-sdk-platform-tools-common (27.0.0+12) ...
Selecting previously unselected package android-tools-adb.
Preparing to unpack .../8-android-tools-adb_1%3a8.1.0+r23-5ubuntu2_all.deb ...
Unpacking android-tools-adb (1:8.1.0+r23-5ubuntu2) ...
Setting up android-sdk-platform-tools-common (27.0.0+12) ...
Setting up android-liblog (1:8.1.0+r23-5ubuntu2) ...
Setting up android-libboringssl (8.1.0+r23-2build1) ...
Setting up android-libcrypto-utils (1:8.1.0+r23-5ubuntu2) ...
Setting up android-libbase (1:8.1.0+r23-5ubuntu2) ...
Setting up android-libcutils (1:8.1.0+r23-5ubuntu2) ...
Setting up android-libadb (1:8.1.0+r23-5ubuntu2) ...
Setting up adb (1:8.1.0+r23-5ubuntu2) ...
Setting up android-tools-adb (1:8.1.0+r23-5ubuntu2) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
ubuntu@ubuntu:~$ sudo apt-get install android-tools-fastboot
android-libbacktrace android-libetc1 android-libf2fs-utils android-libsparse
android-libunwind android-libutils android-libziparchive
android-sdk-platform-tools dmtracedump etc1tool f2fs-tools fastboot graphviz
hprof-conv libann0 libcdt5 libcgraph6 libf2fs-format4 libf2fs5 libgts-0.7-5
libgts-bin libgvc6 libgvpr2 liblab-gamut1 libpathplan4 p7zip p7zip-full
sqlite3
Suggested packages:
gsfonts graphviz-doc p7zip-rar sqlite3-doc
android-sdk-platform-tools android-tools-fastboot dmtracedump etc1tool
f2fs-tools fastboot graphviz hprof-conv libann0 libcdt5 libcgraph6
libf2fs-format4 libf2fs5 libgts-0.7-5 libgts-bin libgvc6 libgvpr2
liblab-gamut1 libpathplan4 p7zip p7zip-full sqlite3
0 upgraded, 29 newly installed, 0 to remove and 163 not upgraded.
Need to get 4806 kB of archives.
After this operation, 19.6 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu focal/universe amd64 p7zip amd64 16.02+dfsg-7build1 [358 kB]
Get:2 http://security.ubuntu.com/ubuntu focal-security/main amd64 sqlite3 amd64 3.31.1-4ubuntu0.2 [860 kB]
Get:3 http://archive.ubuntu.com/ubuntu focal/universe amd64 p7zip-full amd64 16.02+dfsg-7build1 [1187 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libunwind amd64 8.1.0+r23-2 [50.7 kB]
Get:5 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libbacktrace amd64 1:8.1.0+r23-5ubuntu2 [45.2 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libetc1 amd64 1:8.1.0+r23-2build1 [17.7 kB]
Get:7 http://archive.ubuntu.com/ubuntu focal/universe amd64 libf2fs5 amd64 1.11.0-1.1ubuntu1 [14.1 kB]
Get:8 http://archive.ubuntu.com/ubuntu focal/universe amd64 libf2fs-format4 amd64 1.11.0-1.1ubuntu1 [16.6 kB]
Get:9 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libsparse amd64 1:8.1.0+r23-5ubuntu2 [16.0 kB]
Get:10 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libf2fs-utils amd64 8.1.0+r23-2 [11.0 kB]
Get:11 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libutils amd64 1:8.1.0+r23-5ubuntu2 [48.1 kB]
Get:12 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-libziparchive amd64 1:8.1.0+r23-5ubuntu2 [23.5 kB]
Get:13 http://archive.ubuntu.com/ubuntu focal/universe amd64 f2fs-tools amd64 1.11.0-1.1ubuntu1 [154 kB]
Get:14 http://archive.ubuntu.com/ubuntu focal/universe amd64 libann0 amd64 1.1.2+doc-7build1 [26.0 kB]
Get:15 http://archive.ubuntu.com/ubuntu focal/universe amd64 libcdt5 amd64 2.42.2-3build2 [18.7 kB]
Get:16 http://archive.ubuntu.com/ubuntu focal/universe amd64 libcgraph6 amd64 2.42.2-3build2 [41.3 kB]
Get:17 http://archive.ubuntu.com/ubuntu focal/universe amd64 libgts-0.7-5 amd64 0.7.6+darcs121130-4 [150 kB]
Get:18 http://archive.ubuntu.com/ubuntu focal/universe amd64 libpathplan4 amd64 2.42.2-3build2 [21.9 kB]
Get:19 http://archive.ubuntu.com/ubuntu focal/universe amd64 libgvc6 amd64 2.42.2-3build2 [647 kB]
Get:20 http://archive.ubuntu.com/ubuntu focal/universe amd64 libgvpr2 amd64 2.42.2-3build2 [167 kB]
Get:21 http://archive.ubuntu.com/ubuntu focal/universe amd64 liblab-gamut1 amd64 2.42.2-3build2 [177 kB]
Get:22 http://archive.ubuntu.com/ubuntu focal/universe amd64 graphviz amd64 2.42.2-3build2 [590 kB]
Get:23 http://archive.ubuntu.com/ubuntu focal/universe amd64 dmtracedump amd64 8.1.0+r23-3 [26.3 kB]
Get:24 http://archive.ubuntu.com/ubuntu focal/universe amd64 etc1tool amd64 8.1.0+r23-1build1 [18.5 kB]
Get:25 http://archive.ubuntu.com/ubuntu focal/universe amd64 fastboot amd64 1:8.1.0+r23-5ubuntu2 [58.5 kB]
Get:26 http://archive.ubuntu.com/ubuntu focal/universe amd64 hprof-conv amd64 8.1.0+r23-2 [13.2 kB]
Get:27 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-sdk-platform-tools amd64 27.0.0+12 [3564 B]
Get:28 http://archive.ubuntu.com/ubuntu focal/universe amd64 libgts-bin amd64 0.7.6+darcs121130-4 [41.3 kB]
Get:29 http://archive.ubuntu.com/ubuntu focal/universe amd64 android-tools-fastboot all 1:8.1.0+r23-5ubuntu2 [4060 B]
Fetched 4806 kB in 6s (866 kB/s)
Selecting previously unselected package p7zip.
(Reading database ... 190773 files and directories currently installed.)
Preparing to unpack .../00-p7zip_16.02+dfsg-7build1_amd64.deb ...
Unpacking p7zip (16.02+dfsg-7build1) ...
Selecting previously unselected package p7zip-full.
Preparing to unpack .../01-p7zip-full_16.02+dfsg-7build1_amd64.deb ...
Unpacking p7zip-full (16.02+dfsg-7build1) ...
Selecting previously unselected package android-libunwind.
Preparing to unpack .../02-android-libunwind_8.1.0+r23-2_amd64.deb ...
Unpacking android-libunwind (8.1.0+r23-2) ...
Selecting previously unselected package android-libbacktrace.
Preparing to unpack .../03-android-libbacktrace_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libbacktrace (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-libetc1.
Preparing to unpack .../04-android-libetc1_1%3a8.1.0+r23-2build1_amd64.deb ...
Unpacking android-libetc1 (1:8.1.0+r23-2build1) ...
Selecting previously unselected package libf2fs5:amd64.
Preparing to unpack .../05-libf2fs5_1.11.0-1.1ubuntu1_amd64.deb ...
Unpacking libf2fs5:amd64 (1.11.0-1.1ubuntu1) ...
Selecting previously unselected package libf2fs-format4:amd64.
Preparing to unpack .../06-libf2fs-format4_1.11.0-1.1ubuntu1_amd64.deb ...
Unpacking libf2fs-format4:amd64 (1.11.0-1.1ubuntu1) ...
Selecting previously unselected package android-libsparse.
Preparing to unpack .../07-android-libsparse_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libsparse (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-libf2fs-utils.
Preparing to unpack .../08-android-libf2fs-utils_8.1.0+r23-2_amd64.deb ...
Unpacking android-libf2fs-utils (8.1.0+r23-2) ...
Selecting previously unselected package android-libutils.
Preparing to unpack .../09-android-libutils_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libutils (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package android-libziparchive.
Preparing to unpack .../10-android-libziparchive_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking android-libziparchive (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package f2fs-tools.
Preparing to unpack .../11-f2fs-tools_1.11.0-1.1ubuntu1_amd64.deb ...
Unpacking f2fs-tools (1.11.0-1.1ubuntu1) ...
Selecting previously unselected package libann0.
Preparing to unpack .../12-libann0_1.1.2+doc-7build1_amd64.deb ...
Unpacking libann0 (1.1.2+doc-7build1) ...
Selecting previously unselected package libcdt5:amd64.
Preparing to unpack .../13-libcdt5_2.42.2-3build2_amd64.deb ...
Unpacking libcdt5:amd64 (2.42.2-3build2) ...
Selecting previously unselected package libcgraph6:amd64.
Preparing to unpack .../14-libcgraph6_2.42.2-3build2_amd64.deb ...
Unpacking libcgraph6:amd64 (2.42.2-3build2) ...
Selecting previously unselected package libgts-0.7-5:amd64.
Preparing to unpack .../15-libgts-0.7-5_0.7.6+darcs121130-4_amd64.deb ...
Unpacking libgts-0.7-5:amd64 (0.7.6+darcs121130-4) ...
Selecting previously unselected package libpathplan4:amd64.
Preparing to unpack .../16-libpathplan4_2.42.2-3build2_amd64.deb ...
Unpacking libpathplan4:amd64 (2.42.2-3build2) ...
Selecting previously unselected package libgvc6.
Preparing to unpack .../17-libgvc6_2.42.2-3build2_amd64.deb ...
Unpacking libgvc6 (2.42.2-3build2) ...
Selecting previously unselected package libgvpr2:amd64.
Preparing to unpack .../18-libgvpr2_2.42.2-3build2_amd64.deb ...
Unpacking libgvpr2:amd64 (2.42.2-3build2) ...
Selecting previously unselected package liblab-gamut1:amd64.
Preparing to unpack .../19-liblab-gamut1_2.42.2-3build2_amd64.deb ...
Unpacking liblab-gamut1:amd64 (2.42.2-3build2) ...
Selecting previously unselected package graphviz.
Preparing to unpack .../20-graphviz_2.42.2-3build2_amd64.deb ...
Unpacking graphviz (2.42.2-3build2) ...
Selecting previously unselected package dmtracedump.
Preparing to unpack .../21-dmtracedump_8.1.0+r23-3_amd64.deb ...
Unpacking dmtracedump (8.1.0+r23-3) ...
Selecting previously unselected package etc1tool.
Preparing to unpack .../22-etc1tool_8.1.0+r23-1build1_amd64.deb ...
Unpacking etc1tool (8.1.0+r23-1build1) ...
Selecting previously unselected package fastboot.
Preparing to unpack .../23-fastboot_1%3a8.1.0+r23-5ubuntu2_amd64.deb ...
Unpacking fastboot (1:8.1.0+r23-5ubuntu2) ...
Selecting previously unselected package hprof-conv.
Preparing to unpack .../24-hprof-conv_8.1.0+r23-2_amd64.deb ...
Unpacking hprof-conv (8.1.0+r23-2) ...
Selecting previously unselected package sqlite3.
Preparing to unpack .../25-sqlite3_3.31.1-4ubuntu0.2_amd64.deb ...
Unpacking sqlite3 (3.31.1-4ubuntu0.2) ...
Selecting previously unselected package android-sdk-platform-tools.
Preparing to unpack .../26-android-sdk-platform-tools_27.0.0+12_amd64.deb ...
Unpacking android-sdk-platform-tools (27.0.0+12) ...
Selecting previously unselected package libgts-bin.
Preparing to unpack .../27-libgts-bin_0.7.6+darcs121130-4_amd64.deb ...
Unpacking libgts-bin (0.7.6+darcs121130-4) ...
Selecting previously unselected package android-tools-fastboot.
Preparing to unpack .../28-android-tools-fastboot_1%3a8.1.0+r23-5ubuntu2_all.deb ...
Unpacking android-tools-fastboot (1:8.1.0+r23-5ubuntu2) ...
Setting up android-libetc1 (1:8.1.0+r23-2build1) ...
Setting up liblab-gamut1:amd64 (2.42.2-3build2) ...
Setting up libf2fs5:amd64 (1.11.0-1.1ubuntu1) ...
Setting up libgts-0.7-5:amd64 (0.7.6+darcs121130-4) ...
Setting up android-libsparse (1:8.1.0+r23-5ubuntu2) ...
Setting up libpathplan4:amd64 (2.42.2-3build2) ...
Setting up libann0 (1.1.2+doc-7build1) ...
Setting up libcdt5:amd64 (2.42.2-3build2) ...
Setting up libcgraph6:amd64 (2.42.2-3build2) ...
Setting up etc1tool (8.1.0+r23-1build1) ...
Setting up hprof-conv (8.1.0+r23-2) ...
Setting up libf2fs-format4:amd64 (1.11.0-1.1ubuntu1) ...
Setting up sqlite3 (3.31.1-4ubuntu0.2) ...
Setting up p7zip (16.02+dfsg-7build1) ...
Setting up libgts-bin (0.7.6+darcs121130-4) ...
Setting up f2fs-tools (1.11.0-1.1ubuntu1) ...
Setting up android-libf2fs-utils (8.1.0+r23-2) ...
Setting up p7zip-full (16.02+dfsg-7build1) ...
Setting up android-libunwind (8.1.0+r23-2) ...
Setting up libgvc6 (2.42.2-3build2) ...
Setting up android-libbacktrace (1:8.1.0+r23-5ubuntu2) ...
Setting up libgvpr2:amd64 (2.42.2-3build2) ...
Setting up graphviz (2.42.2-3build2) ...
Setting up android-libutils (1:8.1.0+r23-5ubuntu2) ...
Setting up dmtracedump (8.1.0+r23-3) ...
Setting up android-libziparchive (1:8.1.0+r23-5ubuntu2) ...
Setting up fastboot (1:8.1.0+r23-5ubuntu2) ...
Setting up android-sdk-platform-tools (27.0.0+12) ...
Setting up android-tools-fastboot (1:8.1.0+r23-5ubuntu2) ...
Processing triggers for initramfs-tools (0.136ubuntu6.6) ...
update-initramfs is disabled since running on read-only media
ubuntu@ubuntu:~$ adb devices
List of devices attached
* daemon not running; starting now at tcp:5037
* daemon started successfully
XXXXXXXXXX device
ubuntu@ubuntu:~$ adb reboot bootloader
ubuntu@ubuntu:~$ fastboot devices
XXXXXXXXXX fastboot
ubuntu@ubuntu:~$ fastboot reboot
rebooting...
finished. total time: 0.050s
XXXXXXXXXX device
ubuntu@ubuntu:~$ adb reboot fastboot
XXXXXXXXXX fastboot
ubuntu@ubuntu:~$ fastboot oem unlock 0xXXXXXXXXXXXXXXX
finished. total time: 0.000s
Any and all assistance would be greatly appreciated.
