Zebramall
Any Battery case?
I love this phone but the one downside seems to be battery life. I wondered if anyone knows any company who has made or is planning to make a battery case for this phone. It would be absolutely awesome with a battery backup case!
2 REPLIES 2
GTYe0h
You are out of luck here. Battery case is not useful as the phone charges quite slow without PD charger. You can install greenify to reduce battery consumption.
amber_ketch
I think the battery is average.  Consider it comes with a big 21:9 ratio screen.  It depends on what apps you mainly use and how long you run that apps.  A 3000mAh battery is a decent size.  If it is a larger capacity battery, the design of this phone might be thicker.
On the other hand, you can adjust to a different mode to help saving the battery.  It has a few options to select.  You can change to balance mode or battery saving mode if you are not use it for gaming.  However, if you use this phone as a main gaming device, you need to select performance mode to provide more horsepower to run the gaming apps.  That will drain your battery as it requires a full use of ram, screen, and cpu, etc.
It does take a bit time to fully charge.
