I recently purchased a TP-Link RE655BE AP, which supports WiFi 6GHz with both WiFi 6e and 7 protocols. After spending a little time to set it up, I was excited to finally embrace the next-gen WiFi on my 1 VI.
Unfortunately however, my phone wasn't able to pick up the 6GHz-only SSID; although I could use the MLO one (2.4/5/6GHz 802.11b/g/n/ac/ax/be), it just stayed on 5GHz with WiFi 6.
Upon further investigation, I suspect that WiFi 6e and 7 are disabled in Australia as AU is missing from the lists in /oem/etc/customization/config.prop:
ro.vendor.sony.wlan.6e_cc_list=HK,JP,AT,BE,BG,HR,CY,CZ,DK,EE,FI,FR,DE,GR,HU,IE,IT,LV,LI,LT,LU,MT,NL,NO,PL,PT,RO,SK,SI,ES,SE,GB,CH,IS,MY,TH,TW,SG,MO
ro.vendor.sony.wlan.11be_cc_list=HK,JP,AT,BE,BG,HR,CY,CZ,DK,EE,FI,FR,DE,GR,HU,IE,IT,LV,LI,LT,LU,MT,NL,NO,PL,PT,RO,SK,SI,ES,SE,GB,CH,IS,TH,TW,SG,US,MO
According to Wikipedia, Australia allows the same channels as those in UK, and New Zealand allows the same ones as those in Japan. Since both UK and Japan are in the lists already, I hope it's not too much trouble to add AU and NZ too. Could the Xperia developers kindly consider? Thank you!
Hi @MaggieGreene, I'm afraid that didn't help. Could you please file an internal ticket to track this issue? Thank you!
Hi @FrederickZhUK, try the steps in this link: https://www.sony.co.uk/electronics/support/mobile-phones-tablets-mobile-phones/articles/00292437 If the issue remains after these steps, you can contact Sony AU: https://www.sony.com.au/ Or Sony NZ: https://www.sony.co.nz/ they'll be able to assist you further.
Upgraded to 69.1.A.2.189. Still no change unfortunately.
@TheGOAT Thanks for the pointer! May I know how I can get in touch with the technical team?
@FrederickZhUK Here you go I checked, and this is the UK contacting link: https://services.sony.co.uk/supportmvc/en/contact/
Xperia 1 VI owner here. My device cannot see 6 GHz Wi-Fi networks while in Turkey. Other (non-Sony) devices connect to 6 GHz just fine on the same router.
Turkey (TR) has already approved 6 GHz for Wi-Fi use, so is there any plan to add TR to the supported country codes in a future update?
Thanks.
