VAIO TT Series
SOLVED
symandoy
VAIO TT Series
I restarted my laptop, I get the windows welcome screen then the screen goes black.  If I pres Ctrl Alt Delete
I get the option for task manager and the remaining usual options.  Have tried all but screen always stays blank after windows welcome screen
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi symandoy,
Have you tried booting into safe mode (tap F8 at boot)? If booting in safe mode is successful then the driver or service causing the problem needs to be identified. We can provide more detail on troubleshooting this if necessary.
Also you could try booting in safe mode with network support. If this is successful try downloading and running a malware scanner such as Microsoft Safety Scanner.
http://www.microsoft.com/security/scanner/en-us/default.aspx
Rich
Go n-éirí an bóthar leat
1 REPLY 1
rich912
Contributor
Hi symandoy,
Rich
