Screen switches off
vertik
Screen switches off
Hi!
Well I prefer write in spanish but I look forum and a lot of threads are in english for that reason I write in english jejeje.
My problem is this:I use my vaio, when suddenly the screen switches itself off automatically, however it continues running.I know this because the music was still sounding.
Thanks
Carlos
8 REPLIES 8
vertik
yes, sorry
I have a Sony Vaio FS315B
THX
Eftichis
Hi! I also have a FS315B and I have the very same problem; the screen goes off, while the system is still running. Any help?!?!?
Snowball
Have you checked the monitor settings in Screensaver?
R/C on Desktop select Properties click on Screensaver tab click on Power.
You can then set the switch off time there.
Or is this too easy?
Snowball
kee-lo_
Hola Carlos
Might well be due to power saving. If you go to control panel > power then you will see "switch monitor off after", change it to never or a lot longer
vertik
Hi again!
Thanks for replies. But my problem is diferent. When the screen switches itself off, I can't return back to deskpot unless I do a reset....
kee-lo_
That means your inverter or LCD is on the way out
vertik
Hi!
Well, My screen inverter yes.... it puts black
kee-lo_
Yes it's dying
