I have just installed this Codec update provided by Windows Update. After restarting my machine the speaker tray icon showed red cross - No audio out device is installed.
I tried re-installing from disk both using the IDT Audio Codec (failed error 10) and Sigmatel Audio Codec (appeared to work but same error on re-boot).
I was only able to get my sound back by carrying out System Restore to prior to Windows Update.
I believe this update was to provide compatibility with Vista SP1 (i.e. required before Windows Update would offer SP1), but clearly major problem with it.
Any ideas please?
Yep, I have the same problem. i was stupid enough to update, the most funy thing is that in archive that include all preinstalled drivers there are no SigmaTel high audio definiton drivers. Why?
I've found a key to my problem here ftp://ftp.vaio-link.com/PUB/OS/XPDOWNGRADE/SZ4-SZ5/DRIVERS/2_AUDIO.ZIP it's driver for xp, but it goes just fine on Vista too. :smileygrin:
I have the same porblem after doing this windows update.
I have a FE48E
EDIT:
Its not just a VAIO problem looks like a more widespread problem after looking through the web. People with Dells are getting the same problem by looking at there forum, but they have a solution http://www.dellcommunity.com/supportforums/board/message?board.id=dim_audio&thread.id=82248&view=by_... but looks like it will only work for dells
Same here. I don't understand why there isn't an option to uninstall an update. I've tried to uninstall the IDT driver, but it just reinstalls itself automatically.
I have a solution though. Go to device manager, and right click on the IDT driver, choosing "update driver...". Then choose "Browse my computer..." and "Let me pick from list...". Select the SigmaTel HD driver, and everything should be back to normal. Admittedly, I have not restarted the PC yet, but I should think it will sort things out.
[Edit] Didn't work. Had to reinstall the sigmatel driver I still had in the c:\update folder, after downloading it using vaio update sometime last year.
You may be interested to know that I reported this problem via e-Support to Sony Vaio team. They have replied to say that can't provide support for the codecs and told me to do a System Restore to remove the update (which I had already told them I had done).
I think this is very poor - how can Sony not help to resolve the problem on their machines?
I understand Vista SP1 is being delayed by a perceived problem with the Sigmatel codec and this update may have been the way to resolve it so that SP1 could then be offered to Vaio machines. As a result how will SP1 get automatically presented by Windows Update? I understand others have installed it via a standalone download, but I would prefer to install it via Windows Update with the expectation that this is less likely to cause a problem with drivers etc.
How can we rely on Windows Updates if this sort of thing happens and Sony can't help?
A disappointing situation.
I'd be interested in other peoples' thoughts.
I had the same issue.
Just install the sigmatel drivers from VAIO update and everythingwill work again.
Kindest regards,
Nico
I had the same issue..
Kindest regards,
Nico
Same problem here, it broke the sound.
To fix (or if you haven't come across it yet) Allow it to install and break the sound.
Next time you do an update, Service Pack 1 should be available to you.
Install SP1.
Once it''s finished, don't bother with system restore etc, simply rollback the audio driver in divice manager, works for me and I've rebooted since.
