How to access the BIOS for a SVE1712Z1EB
SOLVED
acid_jazz
I need to access the BIOS of a SVE1712ZEB. I tried to follow the Vaio Care Help (got to Advanced Tools then Restore and Recovery then select boot to BIOS). The boot to BIOS option is not available. I have tried the usual F keys to boot to BIOS but none of them work. I need to turn on Hyper-V Platform and I can only do that in the BIOS. Does anyone know how to boot to the BIOS?
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi acid_jazz,
I have no experience of Windows 8 on a Vaio but I believe you need to press the Assist button when the notebook is fully shut down. This should then display the following screen.
Rich
Go n-éirí an bóthar leat
6 REPLIES 6
rich912
Contributor
Hi acid_jazz,
Rich
Blencogo
Hi acid_jazz and welcome.
Like Rich, I have no experience of Windows 8.  Try the solution above first but if it does not work try opening it through Windows 8 rather than Vaio Care.
I think your model has the new UEFI Bios.  Try this: -
On the Start screen pick 'Settings'
Select 'General' in the left column
Click on 'Restart Now' under the 'Advanced Startup' option (this will restart the Vaio into the Boot Menu)
When in the Boot Menu, click on the 'Troubleshoot' icon then 'Advanced Settings'
Select 'UEFI Firmware Settings' to open the BIOS
Let us know if this works.
:thinking:
acid_jazz
Hi rich912,
Your method for accessing the BIOS works.
Thanks for your help.
acid_jazz
Hi Blencogo,
acid_jazz
The quickest way to get to to the BIOS is to use rich912 method. It is the easiest to remember.
rich912
Contributor
You're welcome acid_jazz.
It's good to know that either method works:smileyhappy:
Rich
