bluetooth on VGX-XL302 not showing?
micpayte
How do I turn bluetooth back on VGX-XL302 - not showing in LAN Wireless setting tool but used to be there?
1 REPLY 1
pctech33
I have sony VAIO laptop. You can use Bluetooth in your Sony VAIO laptop. If you have installed Windows operating system in it, you can easily enable Bluetooth because Windows comes with a Bluetooth configuration utility. To enable Bluetooth device in your Sony VAIO laptop, you need to do three things. First of all, you need to have a Bluetooth adapter in your system. Then set up the device so that your computer can find it. Then you can enable the device in the control panel.
_______________
Life is too serious to be taken seriously http://imagicon.info/cat/12-13/text-smiley.png
