Sony KD- 55XE7002 wont stay on
SOLVED
snow71
hi all, ty for letting me join :slight_smile: im here as unfortunately i have the above tv which is being a pain. I turn tv on and it clicks on shows the sony screen and then switches straight off. it does this 3 times then stays off. I cant seem to reset the tv for some reason by following the depressing of the power and - button. it doesnt stay on long enough for me to use the remote. after it clicks off for the 3rd time the led at bottom of the screen is flashing red 6 x below is a pic of what i see when i start it up. any advice greatly received.    many thankstv.jpg
1 ACCEPTED SOLUTION
Accepted Solutions
SkyNet404
Specialist
Hey there, yea at this point I would suggest contacting an engineer, and hopefully they can help you.
6 REPLIES 6
daveyh64
Contributor
The red flashing LED is an indication that something is seriously wrong with your TV, it requires
immediate professional attention. If it is an older TV then just buy a new one.
SkyNet404
Specialist
snow71
hi apologies for late reply. it was a single led at a cost of 160.00 to be repaired 😞
Elodin
Moderator
Hey, the flashing LED wasn't the faulty part in your TV, the flashing LED light is an indication of what is the problem with your TV so that they can identify the issue and repair the TV
snow71
evening, i know it wasn't the flashing led , it was a single led on the backlight so they replaced them all with a new set of sony strips and gave 6 months warranty. fingers crossed it will be back tomorrow. kind regards
Elodin
Moderator
Hey, so they've replaced the backlight panel then, I hope that fixes it and that you continue to enjoy your TV.
