Sony Headphones Cordless connected to Sky Glass Tv .Not Working Now.
elvisthepelvis1956
Hi had Sony Headphones Cordless connected to Sky Glass Tv with Sony surround headphone system, via https://www.amazon.co.uk/Extractor-Converter-Support-Digital-Coaxial/dp/B08XXJ5VT9 all been working fine, Extractor Converter red light on, till I unplugged hdmi cable from Sky Glass TV to exchange for New Sky Glass TV An HDMI cable between the eARC HDMI port (HDMI 2) on the Glass set and HDMI-ARC-in on the extractor unit, now no sound from headphones when I plugged in , An HDMI cable between the eARC HDMI port (HDMI 2) on the Glass set ,please advise, many thanks David.
23 REPLIES 23
LightFoot
Specialist
Hi @elvisthepelvis1956
This is a Sony TV community, but you appear to be asking about a Sky TV and non-Sony gadget. I am sure we can help you with your Sony Headphones. The starting point is the full model number of your headphones and a detailed explanation of how it is connected to your system.
elvisthepelvis1956
 Sony MDRHW700DS Digital Surround 9.1 Wireless Over-Ear Headphones - Silver
optical cable connected from UNSTINCER HDMI ARC Audio Extractor+192KHz DAC Converter to Sony DP-HW700 digital surround processor then  HDMI cable from HDMI ARC Audio Extractor+192KHz DAC Converter to Sky Glass tv into HDMI 2 (e ARC ) port, how I was instructed by  a member of avforum, would be very grateful for advise on how to resolve this issue, many thanks,David.
LightFoot
Specialist
Have you tried missing out the UNSTINCER HDMI ARC Audio Extractor+192KHz DAC Converter from the equation by connecting your Sony DP-HW700 digital surround processor direct to the Sky Glass TV?
I am not familiar with the MDRHW700DS so I might be talking rubbish.
Also check that the audio out from the Sky Glass TV is in the same format as the previous one.
elvisthepelvis1956
what cables would I use and which ports do I connect to.
LightFoot
Specialist
Hi @elvisthepelvis1956   I’m sorry but I will bow out at this stage. With a bit of luck another customer may be able to help you.
HannahEd01
Hey elvisthepelvis1956, stopped at converters, that must be the issue. Try using the optical cable directly if the TV supports it.
elvisthepelvis1956
should this set up work  ?
HannahEd01
Hi elvisthepelvis1956, I don't see why not, where did you get the pic from?
elvisthepelvis1956
From Sony Headphones MDR-HW700DS Manual.
still not working having New Sky Glass TV exchange Thursday.22.9.2022.
UHD quality not happy with,
might be HDMI (eARC Port connection ) ? or try a new HDMI cable from converter to TV unless someone can find a answer I am stuck.
