Old firmware for KD-55XE7096 and error updating
SOLVED
profile.country.GR.title
nbatsis
I tried to update my tv KD-55XE7096 but I found out that my firmware is old (v8.764-1000-1.700-00) and cant be updated online (v8.885) or by usb. When I tried the usb update with this one but I got an error that there is no relevant files in usb "No suitable update data was found".
I also found that to update to v8.885 you need v8.535
I did search in support site and I could find only the one before (v8.535).
I tried to update via usb to v8.535 but I again received the error "No suitable update data was found".
Where can I find firmware files older that v8.535???
Or am I doing something wrong with the usb update to get this error ?
I did formated usb to fat 32 and followed the instructions for usd update.
Any help is appreciated.
Nikos
15 REPLIES 15
profile.country.DK.title
stixix
Now on v8.885 :slight_smile: I don't exactly know what worked - but I prepped my usb like below - and then updated it. It went directly to v8.885. Which file it actually chose to pick up, I do not know - but probably this one: e:\sony_dtv02B40B09B4BD_00200100\00200100_22B50000.pkg
Let me know if this works for you.
I got the links to the files from a nice person at Sony - thanks Sebastian :slight_smile:
v8.535 - https://www.sony.dk/electronics/support/downloads/00015050
v8.885 - https://www.sony.dk/electronics/support/lcd-tvs-xe70xx_x70xxe_x72xe-series/kd-65xe7096/downloads/000...
/stig
nbatsis
Hi Stixx
Can you tell me how you formated your USB fat32? NTFS?
Kind Regards
Nikos
stixix
Fat32
nbatsis
well I did what you are describing and I have the same result.
TV says that there is no upgrade in the usb....
I have to find someone in Sony support Greece...
Thank you
Nikos
stixix
Hmm - I can create an image of the usb stick, and send it to you?
nbatsis
Well I finally managed to update the firmware for my TV.
I had to do a factory reset first then I had to go through the initial setup of the set and afterwards I did update the firmware with the same USB stick that I was trying to use before.
So to summarize the steps if you are getting the error "software update is not available in TV current mode"
Do a factory  reset
Do the initianilation steps
Do the update from USB (it might work if you do the Internet update as well... I didn't try it)
----Magic you have an updated TV set!!!
