KD-55XE7002 turning off and on every few seconds
gdpower
New
works for about an hour then turns off and on every few seconds. tried factory reset but did not fix the issue. Any suggestions?
3 REPLIES 3
LightFoot
Specialist
Hi @gdpower
With a bit of luck you are still within your 5 year warranty (if bought from a major retailer). I would contact Sony for support a.s.a.p.
https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=televisions-projectors-lcd-tvs&tab=Tips
gdpower
New
Thanks for response.
out of warranty. Wondering if anyone else had similar problems and was there a solution other than bringing it to a repair centre
SkyNet404
Specialist
Hey there,
I would say if it stays long enough, make sure to check for a software update: https://bit.ly/3IAyyUx.
And if it's still the same, sadly you will need to contact an engineer about that one: https://bit.ly/3tE97K0.
Hope it helps!
