Freeview HD
Freeview HD
Just bought a new TV from John Lewis. By all the information online including Sony's own website, it has a built in Feeview HD tuner. However I cannot get any HD channels. All the other TVs in the house receive HD channels & there is nothing wrong with the cable. I reported this to John Lewis who supplied a replacement TV which has the same issue.
Help!
The TV is:-
Sony Bravia KDL32W705C
Can anyone help me solve this problem?
2 REPLIES 2
Anonymous
Not applicable
Hi there
Most of the time this problem is due to something on your side. I would test using the same aerial lead and aerial point from one of your tvs that does work.  Also check the signal strenght and signal quality on the other tvs.
Also, have a look at the EPG and see if there are any/many in the 800 range as you might be picking up a weak signal from another transmitter instead.
You might want to try manually tuning in the channels, see
http://www.digitaluk.co.uk/coveragechecker/manual_retuning
Cheers
angelacr
Sounds odd. Freeview isn't too usr freindly putting HD channels in the 100+ range. You have tried scrolling through the guide to this channel range?
