Connect the bluetooth headphone with tv
SOLVED
profile.country.SE.title
eyad85
Hi
I hope you can help me with that problem.
I have sony tv " KDL-50W815B " and recently bought a headphone " WH-1000XM4 "
I tried to connect them together but i didn't sucsses.
I looking for a bluetooth sender maybe it can help me in that case and i found that one " WLA-NS7 " but i'm not sure if i can use it with my tv because it's for XR tv as i can read.
Should it work if i have it so i can hear the tv from the headphones i have?
Best regards Eyad.
1 ACCEPTED SOLUTION
Accepted Solutions
LightFoot
Specialist
Hi @eyad85
Looking at your Reference Guide you do appear to have an Optical output. However I cannot see any USB ports? It should work but you may have to supply an external USB power supply.
Just in case you are not aware this is only a community of customers. There is no input from Sony.
Generic Bluetooth transmitters are very common. I don’t know if Amazon is available but you can take advantage of buying and returning if they don’t work. I would go for a quality product, the cheap ones are useless. Sorry I cannot recommend any as I don’t need one. My WH-1000XM5 connects direct to my XR-55A95K.
5 REPLIES 5
LightFoot
Specialist
Hi @eyad85
Looking at the specifications for your TV it doesn’t appear to have a Bluetooth radio! So the chances of connecting any Bluetooth device is zero. You should explore using an external Bluetooth transmitter connected to your existing audio outputs.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-50w815b/specifications
Edit: Sorry please ignore me, I didn’t read your question fully. The WLA-NS7 uses an Optical Digital input, so if your TV does not have a Optical output then it cannot work. Bluetooth transmitters for your available audio outputs are readily available, just not Sony.
eyad85
Thanks for your answer.
Do you think it will work if i buy that?
https://www.sony.se/electronics/tradlosa-hogtalare-dockor-tillbehor/wla-ns7#product_details_default
/Eyad
eyad85
Thanks again.
Can you show me please how it look like. And should i just looking for Bluetooth transmitters?
eyad85
I think i have thats it you mean "Optical Digital output" and maybe my tv is XR as i can see in the
features you sended to me.
LightFoot
Specialist
Hi @eyad85
