Changing image size whilst watching netflix content via netflix app
walmerbullar1
Hi
I have just purchased a KDL50W829.   The problem I am having is that when I watch content via Netflix, I do not have the option of changing the image size - so that I can watch without letterboxing.
When watching normal TV I select - OPTIONS -> Screen Format and can then choose from Wide Zoom, Normal, Full etc.
However within the Netflix app when I select OPTIONS - I have only Picture Options, Sound Option, Scene Select and 3D settings
Hope that someone can advise...
9 REPLIES 9
rooobb
Have you tried the size button left bottom of the remote?
walmerbullar1
Hi - sorry, but there isn't a size button on the remote contol for this model.
Thanks, John
trmilbu34
New
Try this when watching DVD, Netflix or any other input
Press the Sync Menu button
Select TV Control, you then have access to Screen Format where your Zoom facility is available
Hope this helps
amj20092
New
Netflix sends 4:3 want to change to full screen have Sony Bravia sync menu and wide screen not available, is there a solution?
Did you find a fix for this? Thanks.
Hello I need to know how to change this aswell ... also the amazon app is the same .. very disappointed at the moment 😏
leeard
New
Pickers48
New
I Just bought the 43" KD43XH8096 Sony Bravia Smart TV & it does the same thing, on tv mode I can zoom in but not on Netflix App (Feature Not Available), is there an answer to this question?
Win_88
Specialist
Hi @Pickers48
This is just a limitation of the source you're watching. Some options in the Action menu may be greyed out or not available depending on the source (so you may be able to change certain settings when watching TV, but not when using an app for example).
It's recommended to keep your TV up to date at all times any, just in case this changes in the future.
Win_88
