problem record to USB stick on New Bravia 43 KDX85J tv
profile.country.IE.title
TEXAS66
tv registers The USB stick and sets the recording but then says USB almost full when it is empty and errors to say no registered device.
3 REPLIES 3
Marino.Manolo
Try to reboot Android TV, press and hold the Power/OFF button on the Remote or try a Factory Reset.
TEXAS66
thanks for your reply
I had tried all that with no result., I have just posted my fix now.
thanks again
HannahEd01
Hey TEXAS66, where are you based?
Also, try the below:
-Make sure it's up to date and if not update it, the instructions are here: https://www.sony.co.uk/electronics/support/lcd-tvs-android-x85j_x86j_x89j-series/kd-43x85j/software/...
-Format your HDD to one of these: FAT16/FAT32/exFAT/NTFS
-Make sure that you're using an HDD, not a USB as it will not work, check what are the compatible HDDs here: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xf7596/artic...
-Check this: https://helpguide.sony.net/tv/iaep1/v1/en/03-01_05.html
Let me know if you're still having an issue.
