KD43x72k
stbromf54
New
KD43x72k
I’ve had this TV for 3 months and have experienced continual problems with antenna reception.
I have a new Aerial ,a booster and filter installed.The aerial engineer has tested twice and all channels should be constantly available.
The TV will suddenly drop a batch of channels.Sometimes HD channels and later non HD.
A reset will bring the channels back but not always.
Fast coming to the conclusion there is a problem with the TV.Any one else experiencing this or have theory on what is occurring here?
2 REPLIES 2
HannahEd01
Hey stbromf54, please follow the sequence below, and test after each step:
-Unplug the TV from the mains for two minutes while disconnecting any external devices, including the aerial.
-Make sure your TV is up-to-date, following the steps here: https://www.sony.co.uk/electronics/support/lcd-tvs-android-x72k_x73k-series/kd-43x72k/software/00281...
-Unplug the TV, remove the aerial, tune the TV while the aerial is out. You won't get any channels.
Repeat the step while connecting the aerial, then restart your TV.
-Reset the TV to the factory settings: https://helpguide.sony.net/tv/jaepm2/v1/en/3_8_factory_reset.html?hl=reset
-If possible, test the aerial with another TV.
Let me know how it goes, please.
stbromf54
New
Thanks for your reply and the information.I have other issues with this TV,however I will use your recommended actions when I can.
