A1 and imaging edge
rddmail
A1 and imaging edge
I have had my A1 for a week and I want to shoot in raw, whilst I understand that I have to wait until LR or Capture one supports the camera I would have thought that Sony's Imaging Edge would work properly, firstly I can't find the card in finder when I shoot in raw ( no problem when I use jpeg) when I can locate it after some difficulty it shows the raw files as thumb nails but says they are corrupted when I try to open them. I have downloaded the latest version of Imaging edge. I use an iMac running the latest operating system. Not a good start
RDDIMAGES
3 REPLIES 3
Which MAC OS are you running?
Currently MAC OS 11 is not supported by IE - so maybe this would cause this issue.
Also please verify again that you're running the latest software:
https://support.d-imaging.sony.co.jp/disoft_DL/desktop_DL/mac?fm=en
Cheers
Peter
rddmail
Thanks Peter,
Yes I am using Big Sur, so that is probably the answer. Disappointing to have to wait for third party software to be able to shoot in raw but it is what it is I suppose
Roger Daniel
Aberfoyle
Coity
Bridgend
CF35 6BE
rddmail@btopenworld.com
RDDIMAGES
Joe_Dohn
Specialist
@rddmail you should remove your personal info from the post.
